Upload ESRI Python extensions to PyPi
1700
04-23-2015 06:15 AM
Status: Implemented
ChrisMathers
ESRI should place python modules they develop outside the arcpy package on PyPi so we can pip install them which is more convient than GitHub.
4 Comments
TedCronin
At Dev Summit is was mentioned that they would be supporting conda and do something similiar
ShaunWalbridge
All of the packages we use for ArcGIS Pro (and Server) are now uploaded to our Anaconda Cloud channel, at https://anaconda.org/esri/. You can use them in Pro, or use them in an external conda environment. If you have other Esri Python packages that aren't there which you'd like to see, let us know.
DanPatterson_Retired
Throw them in here as well... ArcGIS code sharing
ShaunWalbridge
ArcPy is available as a conda package, which supports the full set of dependencies.
