Upgrade Point To Line tool
2583
11-10-2016 02:26 AM
Status: Implemented
DuncanHornby
MVP Notable Contributor
The geo-processing tool Point To Line is a python script tool found in the Data Management > Features toolset. As it is a script one is able to look at the source code. I notice that the code was developed using the older slower cursors. This less efficient code still persists in 10.4.1.
So my idea is that ESRI upgrade the code by replacing the current older slower forms of cursors with the cursors from the da module.  Even ESRI say you should be using those as they are faster and more efficient! The upgrade should be for future versions of ArcMap (10.5 onwards) so as to not break the tool for users stuck with older versions of ArcMap.
3 Comments
Bud
(Migrated from a separate idea.)
It looks like there are OOTB Esri geoprocessing tools in ArcGIS Pro that use the old/slow cursors.
Example: Points To Line GP tool
If we look at the code for those tools, we can see that they are outdated. They use the the old/slow cursors instead of the new/fast cursors in the DA module.
Could Esri update all GP tools so that they use the new DA cursors/module?
DrewFlater
MargaretCrawford
This idea has been implemented in ArcGIS Pro 3.2. The points to line tool was rewritten for faster performance and provide progress updating.
Please see the What's New documentation for more new features in Pro 3.2.
