It would be great if a relinked table frame in a layout could honour the field/format/style values previously defined. For instance, I have tables in one GDB that match the schemas of a similar GDB, which has data linked to a separate map. I would like to either duplicate the original table frames and relink to the new data in a separate layout, or to duplicate the layout, change the underlying map, and then update the table frame sources.
Neither option currently works. The table frame provides a default list of fields for the newly linked feature class.
