Smart Form calculations maintained when editing in ArcGIS Pro
714
08-12-2024 05:08 PM
Status: Open
MJhendo
I have a Web Map setup in ArcGIS Online with a Hosted Feature Layer, with one field setup with an arcade calculation using Smart Forms. When I've added the Web Map directly into ArcGIS Pro (via our AGOL portal connection), the Smart Form configured calculation does not work when editing in Pro.
It would be ideal to have these configured Smart Form calculations pass through into ArcGIS Pro when editing, considering we are unable to setup attribute rules on hosted feature layers. Alternatively, give the option to configure a calculation within the template configuration. We are currently forced to use nightly post-processing in order to add these calculations in that should be available as part of editing in Pro.
Using arcade pop-up is not a viable solution for all situations, as this only provides a dynamic solution within the pop-up, not the underlying feature attributes, which we require for other processes.
