Set your own defaults for service publishing
3152
6
10-12-2017 01:41 AM
Status: Open
L_Doorn
When sharing a service, the service editor screen displays the default settings as programmed.
It is now not possible to adjust the default settings.
It is highly desirable that this will be possible.
It simplifies management when creating a service and ensures that a service is created in accordance with the business rules.
6 Comments
TylerBragg2
It does irritate me that when I share a service from ArcGIS Pro that I'm not afforded the ability to change the sharing settings and how editing will be controlled. I would greatly appreciate greater management control at the publishing stage.
JTessier
In addition since Im not sure the OP clarified this, as it relates to business rules:  it would be good if the original publisher (publisher role) of a service was constrained to certain values/params (cannot create tile cache) that are set at the enterprise level, that only admins could change.  As those params (in that example) could be detrimental to resources (storage space) for the entire server.
RTPL_AU
Edit: Merged from separate Idea.
Add functionality to Pro to remember, or be able to set defaults in Pro Options, of settings used in the Share as Web Layer process. For example allow us to set Timezone management options, Feature Properties > Operations, etc  that are used very often.
If I have to publish 50 separate layers it means I have to set the timezone, enable sync, allow editing, etc for each layer.
RTPL_AU
Add an option to set a timezone default for sharing so it isn't necessary to set the timezone for each & every layer that gets published.
RTPL_AU
For example. I am publishing 9 layers to AGOL today.
With the 6 extra mouse clicks for each layer it means there are 54 EXTRA CLICKS than if there was a default possible for the project.
RTPL_AU
Bonus Points - Set defaults for the entire sharing process for a project so we don't have the specify Folder, Sync, etc each time.
