Set symbology’s lower value manually in ArcGIS PRO
18797
15
08-21-2020 06:25 AM
Status: Already Offered
CordulaGöke
Lower class value of the lowest class cannot be manually changed (it was the same in ArcGIS).
You can update by choosing advanced-> sample size-> set sample size up, if you have not chosen “manual interval”. If you have chosen “manual interval”, not even that will work. If you realize too late that not all your data is covered or want to import symbology, there is no way around to set all class values manually again. There is no option only to update the lower value. The new sampling will always change the class values based on the chosen method and the new histogram.
You can actually set the upper value of the first class lower than the automatically estimated lower value. This is different from ArcGIS and changes the situation from being annoying to being a bug.
The new thing is that you can add “out of range” as a new feature in pro, but again the same, there is no way to update the range once you are in manual interval, you can change the upper value for the lowest interval, but the data will be shown as out of range and that is wrong and a bug.
The preferred solution is to be able to set the lower value manually, than you do not need to update with large samples and you can prepare the symbology for possible future lower values in dynamic data. Additionally, it would be easier to move the sampling from the advanced to the histogram-menu.
In the example I imported symbology from another layers based on latitude onto the column longitude. It is completely out of range, but normally I would want to keep the class limits. I calculated the statistics for the lon column in the table and then chose an upper value which definitely lies in the range of Lon. I added out of range symbols, otherwise the map would be simply white. The points would not be selectable. Choosing to update the range during support would change all class limits when anautomatic classification was chosen in the original layer and not update when "maual interval" is chosen.In the example I imported symbology from another layers based on latitude on the column longitude. It is completely out of range, but normally I would want to keep the class limits. I calculated the statistics for the lon column in the table and then chose an upper value which definitely lies in the range of Lon. I added out of range symbols, otherwise the map would be simply white. The points would not be selectable.
15 Comments
RyanCoodey
In Classified Renderers, when manually setting the "Break Values", you can set a break greater than the maximum statistic, but you can NOT set a break lower than the minimum.  It forces you to the value of the minimum statistic.  What if you have data that might go lower than this in the future?  What if you just want to set nice clean breaks?  I don't see why the smallest break must be greater than or equal to the minimum statistic.
This can be gotten around by loading values from another data set, but this is a lot of extra work to setup that data as needed.
PhilippMarty
In ArcMap: If you want to set break values manually during a classification, the minimum break value is not allowed to be smaller then the datas minimum value. Of course there is a work around (--> import a predefined lyr-file), but it would be helpful to define the minimum break value without the mentioned limitation.
CordulaGöke
The same applies to classified symbology for vector data. At the moment it is in ArcGIS Pro even possible to set the upper value of the first class lower than the range that ArcGIS automatically calculates. The lower value does not get changed in this process. Connected to this is the option to recalculate the range with higher sample size. This option should be moved from advanced to the histogram menue. If you have already chosen manually changed classes, the lower value will not update, so you have to change back to one of the automatic class options and manually enter the ranges afterwards. Also for importing symbology from .lyr does not offer the option to adapt the lower value to the class range in the current data.
CordulaGöke
Today I learnedthat it is possible to text edit the *.lyrx. So if I take the step to export to lyrx, it is actually possible.
ChelseaRozek
First time running into this issue for me. Surprised to see this idea from 2010. More than 10 years later, Pro can't do this. I'm trying to make a COVID-19 vaccination rate map with graduated colors. They want a set of colors each 10% from 0-100% so we can compare maps over time. I can't set an interval range for lower than our lowest vaccination rate.
lzk222
Yet another instance where ESRI comes up short. QGIS handles this much better. My advice is to create a new category column based on the ranges of the values you wish to symbolize and then symbolize based Unique values. For instance, I want to create 5 classes and one "No Data" class. I write the logic (CASE WHEN is a good option) for the classes and just produce the text outputs in a new column (ddi_cat). Screenshot 2022-08-16 121053.pngScreenshot 2022-08-16 121053.pngThis is QGISThis is QGIS
Screenshot 2022-08-16 120149.pngScreenshot 2022-08-16 120149.pngScreenshot 2022-08-16 120951.pngScreenshot 2022-08-16 120951.png
Note I created the new column in QGIS but there is probably a way to do it in ArcPro. In general, I highly recommend getting familiar with QGIS, especially when it comes to symbology. It has superior UI, functionality and customizability. I generally map things out in QGIS and then transfer them over to ArcPro for the web mapping features.
CraigWilliams
The lower value is shown and editable in the histogram view as shown in this GIF.
The example @lzk222 shows can also be done with an arcade expression for class breaks or unique value symbology. In that case the expression itself is configuring classes.
CraigWilliams
DWR_BuckEhler
@CraigWilliams , I think you missed the point. Users would like to sort by using a 'Lower value' in the graduated symbology classes rather than an upper value.
I just ran into this today and have an example for acres. I would like symbols to go something like this:
≥50
≥ 400
≥ 2000
≥ 4000
≥ 8000
≥ 12000
≥ 20000
≥ 30000
Below is the best that I can do currently:
We could do a lot of modifications to the labels to clean this up but it takes a lot of time and if anything changes, we have to start over again.
Buck
MaxMolello
Craigs answer works for me, changing the minimum value in the histogram forces the classes lower than the data minimum values, although I would have never known that was editable, it doesn't look like it is until you double click the number.
On a side note, the classes make it seem like everything below your current class is included since it says the upper value of each class is less than or equal to the value, I think that is misleading if that is actually limited to the set lower value in the histogram.
