Set Default Select Tool in ArcGIS Pro
5868
19
01-03-2025 07:17 AM
Status: Implemented
RobertAnderson3
MVP Regular Contributor
The select tool defaults to the rectangle select, I almost always would prefer the Lasso tool. There should be an option to set your default choice of selection in your projects.
Tags (1)
19 Comments
ChristineSalvadore
The Select tool always resets to "Select by Rectangle", which is not useful for my purposes. I always switch to Select by Lasso. I would like to be able to make this my default select option in Pro, or even making it defaulted to a specific project file.
Markbe_utco
Agree
Michele
Please at least make this an option in selection settings.  It's very annoying every time I start a new ArcPro session I start to draw a selection area and need the lasso, not the rectangle.
MT_JenAmes
I would like to see the ability to set a default for the Select tool in the Selection section of Pro's settings. The rectangle is one of the least useful options in most of my use situations, so I always change to the lasso, but it would be great if that was just something I set once, and didn't have to do again (or at least until the next update).
DanPatterson
you might want to jump on this idea tool
Set Default Select Tool in ArcGIS Pro - Esri Community
or perhaps the ideas can be consolidated
MT_JenAmes
Ah I had searched for an existing Idea and didn't see anything! Not sure how I missed this. Thanks for the link!
Head_In_The_Clouds
I like the idea. It would be cool to set the default opening tool as well. It's always Explore, but we use Select much more often.
NathanShephard
Thanks for submitting this idea.
Rather than yet-another backstage configuration setting, how would you feel about having the active Select tool remembered over multiple Pro sessions?
So if you close Pro with Select by Lasso active, it would be the default select tool in your next Pro session.
-Nathan.
Michele
Hi Nathan,
Maybe that’s a feature in 3.4 but my company is still on 3.3 and that doesn’t occur.
NathanShephard
Thanks Michele!  My apologies, my note wasn't clear.
Pro does NOT currently remember which Select tool you used last - it resets to Rectangle every time.
However, IF it did remember it, would that meet your need? (IE: rather than requiring a setting).
Thanks!  Nathan.
