Selected Feature's Attribute adding to Layout
2341
10-10-2023 04:22 AM
Status: Open
HarishKV
In ArcGIS Desktop there is a provision to show only the selected feature's attribute table to the Map Layout. But this particular functionality I am not able to get it in ArcGIS Pro. Its wonderful functionality that will help users who create Map Layout frequently.
4 Comments
KoryKramer
Hi @HarishKV
You could create a selection layer and then have your layout's table frame reference the selection layer. Does that satisfy the workflow?
HarishKV
@KoryKramer that doesn't work in my case, because i have to use it in ExB
HARTerra
Currently the Table Frame element in ArcGIS Pro supports showing "All Rows" or "Visible Rows" in the query property.  It would be good if the Table Frame element query also supported only displaying "Selected Rows".  This would need to work with feature tables and simple tables.  This would allow users to select data they want to highlight and have that show up in the Table Frame.
RichardHowe
As a workaround, you could select the data you want to show, create a new layer from that selection in your map frame and point the table at that
