When publishing from ArcGIS Pro it would be great to be able to select from a drop down or search ahead list of existing tags.
This would achieve at least 4 benefits:
Thank you for submitting this idea @MarkMenzel1
Since there is an existing idea about incorporating a portal's Categories here https://community.esri.com/t5/arcgis-pro-ideas/incorporate-portal-content-categories-with-arcgis/idi... (please go add your support by giving that kudos if you haven't yet), could you please modify your idea to be about Tags only?
Let us know when that is done and we will get the idea re-opened.
Thank you!
