Select tags from portal when publishing
2669
6
08-15-2021 11:33 PM
Status: Implemented
MarkMenzel1
When publishing from ArcGIS Pro it would be great to be able to select from a drop down or search ahead list of existing tags.
This would achieve at least 4 benefits:
  1. The list of tags in the portal would not have typos or spelling errors
  2. Users would know what others and the portal admins are using as tags e.g. water vs hydrology.
  3. Users would not have to go into an item after publishing and update the details.
  4. Limits the list of tags and saves time for admins in clean-up of bad tags
6 Comments
KoryKramer
Thank you for submitting this idea @MarkMenzel1
Since there is an existing idea about incorporating a portal's Categories here https://community.esri.com/t5/arcgis-pro-ideas/incorporate-portal-content-categories-with-arcgis/idi... (please go add your support by giving that kudos if you haven't yet), could you please modify your idea to be about Tags only?
Let us know when that is done and we will get the idea re-opened.
Thank you!
MarkMenzel1
Hi @KoryKramer,
I have updated the idea to only refer to tags.
Cheers,
Mark
KoryKramer
Status changed to: Open
Thank you @MarkMenzel1
The idea is Open again for community members to vote.
Cheers
JonahLay
JonahLay
SusanTran
This will be available in ArcGIS Pro 3.5.
