Select By Location (using "Have their Centroid in") should have "inside requried" option
3129
02-13-2015 06:05 AM
Status: Open
ChrisMcGarry1
When using select by location/Have their centroid in option the geometry selection engine appears to use the literal centroid.  With "U" shaped geometries the centroid will lie outside of polygon and will not be selected.  We would prefer to do spatial selections using the forced inside centroid and not using something like intersect, or a negative buffer, etc... as the results are unreliable for our situations.  To get around this I must make a centroid FC (using the inside option) run a spatial section against it then join back the results to the original layer to subset which take quite a bit more time than something a check box (or an alternate spatial selection method) could provide.
2 Comments
JeffThomasILM
The "centroid inside" option should exist for the Spatial Join tool, too. Do the Select By Location and Spatial Join tools use the same code/logic?
KoryKramer
Adding this comment from: https://community.esri.com/ideas/19011
