Scale-based Definition Queries
3465
7
07-11-2023 10:32 AM
Status: Open
MilesL1
Using definition queries, one can display different subsets of one dataset at different scales (ie, reducing the quantity of points shown based on some attribute as the user zooms out). This requires that each definition query has its own layer. When dealing with a map with a wide scale range, this may result in very many layers with the same symbology, but different definition queries. I would like to suggest that definition queries can be applied to scale ranges within one layer (or, a scale range can be applied to a definition query).
Ie. from 1:1,000-1:30,000, apply one definition query
from 1:30,000-1:100,000, apply another definition query
This can help keep the quantity of layers in a map down, and reduce duplication of symbology and label classes.
7 Comments
KoryKramer
@MilesL1 have you tried display filters? https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/display-filters.htm
Would that work for your use case?
MilesL1
No, because display filters leave the data in the map, just "invisible" (unsymbolized).
Andrew-Bowne
Are display filters supported in a Web Map?  From what I can see they are not. Can anyone confirm?
Andrew-Bowne
Thanks, Kory.  As with so many Esri products, the answer is:  "It depends"...  I'm using a Feature Service so it looks like the answer is "no" in this case.
ERex
Scale-based definition queries would be great! Hope this gets implemented.
PavelSeemann
That’s a good idea. It would be helpful to be able to set different definition queries for different scales within a single layer. Display filters do allow this, but "invisible" features remain clickable. This behavior carries over to the published web map and confuses end users, who see pop-up windows for features that aren’t visible when they click on the map.
