Return Enterprise Geodatabase Dataset Permissions
1845
06-26-2023 01:39 PM
Status: Closed
mpboyle
Honored Contributor
Please create a geodatabase/arcpy tool that returns permissions on an input enterprise dataset.  There are cases when we have new staff start and they need/want the same permissions as another user.  It would be nice to be able to iterate over datasets in a geodatabase, get the permissions on a particular dataset and be able to check what permissions a certain user has.  In this example, I could set a target user name and if found, assign the new user the same permissions as the target user.
The return could be something like either of the following:
return = [{user: UserName1, edit: True, view: True}, {user: UserName2, edit: False, view: True}]
return = [{user: UserName1, select: True, insert: True, update: True, delete: True}, {user: UserName2, select: True, insert: False, update: False, delete: False}]
3 Comments
ChetDobbins
@mpboyle
I am wondering whether using database roles would help you achieve the same solution and ultimately make managing database permissions much easier. What i am suggesting is that you would create database roles that fit each user groups specific permission needs, then grant the needed permissions to the roles. When a new staff needs to connect to the database, you can determine which permissions role they fit into and simply create a new database user and add it to that database role.
HannesZiegler
Please see Chet's potential solution using existing tooling in the post above this one. His question is quoted here for convenience.
-ChetDobbins
HannesZiegler
Status changed to: Closed
Thank you for submitting your idea for a tool to inspect enterprise geodatabase dataset permissions. We appreciate your suggestion. At this time, we are not pursuing this idea given that a best practice solution was offered, and we received no further feedback.
The solution to consider is as follows:
  1. Create database roles
  2. Assign users to those roles
  3. Assign permissions to the roles that each user group requires
  4. When a new user comes online… determine what permissions they need and assign them to the appropriate role or roles.
See the original response by @ChetDobbins:
-ChetDobbins
Thank you again for your contribution and understanding. If you have any further questions or concerns, please do not hesitate to contact us.
