Request to add an "Advanced ArcMap Settings" utility in ArcGIS Pro, similar to the one available in ArcMap.
873
06-19-2025 07:37 PM
Status: Closed
SunkubbDev
Requires the use of the "Advanced ArcMap Settings" utility available in ArcMap.
However, this functionality is currently not available in ArcGIS Pro. Therefore, we would like to request that this capability be added to ArcGIS Pro to work in the same way as it does in ArcMap.
https://desktop.arcgis.com/en/arcmap/latest/get-started/administer/advanced-arcmap-settings-utility....
3 Comments
AyanPalit
@SunkubbDev Thanks for the idea.
  • Most of the Advanced ArcMap Settings are at Project options  ; recommend reviewing those.
  • Be specific in terms of the functionality requested. The screenshot is generic and shows the application exe.
  • It also helps to mention the use case, how you use this in your workflows
ValeriaChavez
Hi @SunkubbDev! As @AyanPalit noted in his comment, most of this should be available through the ArcGIS Pro project and application options. Could you update the Idea to specifically note what functionality is missing and the use case behind it? Thank you.
ValeriaChavez
Status changed to: Closed
Hi @SunkubbDev! This Idea has been set to "Needs Clarification" for a bit. We haven't received any additional information / details so I will be closing the thread. For more information on project and application settings for ArcGIS Pro, please refer to the relevant documentation here: https://pro.arcgis.com/en/pro-app/latest/get-started/options.htm
