Pro version 3.1.3
I've been running into this problem recently.
In short, using the Exclamation point to fix broken links has limited functionality.
TLDR: the Exclamation point will repair Esri data types (except mobile geodatabases) + and maybe one thing else, even if everything is in the same folder.
This is not a problem if using the catalog pane to update a map's sources with a find/replace.
In the screenshot below, I have several layers and views pointing to data of the following types:
Here's the thing. All of these data sources, as you can see, are in the same folder.AlfredBaldenweck_15-1734391581718.png
If I use the exclamation point to repair the sources, I get the following results:
Note: I am starting from a fresh map each time.
| Thing repaired | Yield | Picture for proof |
| DBF or SHP or TIN or file Geodatabase Contents or standalone rasters |
| CAD data |
| Mobile geodatabase |
| Geopackage |
| KML |
| Excel Sheet |
Please improve the functionality of this workflow to properly repair all data sources at once.
Repairing broken sources is a very poorly thought out functionality in ArcGIS Pro, just like it was in ArcMap. Robust and automated repair of lost sources, which helps the user quickly solve such a tricky problem, is a much-missing functionality in ArcGIS Pro.
Why not learn from those who can do it better? Adobe After Effects, for example, has an excellent and user-friendly solution for repairing lost sources.
