Reorder manual legend columns
762
05-16-2023 08:05 AM
Status: Open
wayfaringrob
Honored Contributor
Right now with the manual columns legend fitting strategy, you can't reorder your columns -- only the legend items within them. If you decide you'd like to move your columns around, you're out of luck. It would be great if you could drag to rearrange them just like you can the legend items. The workaround is to drag each item individually.
2 Comments
TomBole
@wayfaringrob ,
Not sure if you are aware, but you are not limited to dragging each legend item individually into a new column. You can select multiple legend items using the SHIFT or CTRL keys and move the group into a new column.
Tom
wayfaringrob
@TomBole  I was not, thanks for the tip! Would still make sense to be able to rearrange the columns themselves; everything else in the TOC is movable.
