Reference scale new toolbar command
1003
11-21-2018 04:58 AM
Status: Open
GergelySzalay2
I made a customised toolbar gathering together the Reference Scale functions but for this I miss very much a new command working similarly to the map scale dropdown menu, where you could select the new reference scale or set by hand, without the need to go to the Data Frame Properties window.
1 Comment
KoryKramer
Hi Gergely Szalay‌  Can you provide more details about the functionality you're looking for?
In ArcGIS Pro, I can add the Set Reference Scale command to the Quick Access Toolbar making it available from whatever view I'm in:
After playing with this a bit more, my understanding is that you would like to be able to add the Reference Scale dropdown control to a toolbar/ribbon?
You could just use the map scale control and then Set Reference Scale to not have to go to Map Properties.
