Real Time connectivity of Layer attributes with database tables in ArcGIS
1190
09-05-2018 01:52 AM
Status: Open
AnkanGhosh
Event layer refresh category should have a add functionality to reload updated data from connected databases like SQL Server/Postgre DB if there are changes or updates in database. Currently the functionality to refresh the points and attributes are limited to event layers and there are no functionality to fetch the refresh data from database to Event Layer in real time.
2 Comments
KoryKramer
ArcGIS Pro supports stream services for real-time data: Stream layers—ArcGIS Pro | ArcGIS Desktop
Does the refresh interval for layers not work for you? Set layer properties—ArcGIS Pro | ArcGIS Desktop
AnkanGhosh
Hi Kory,
Thanks for your answer.
Refresh interval for layers doesn't load the refresh data from Database. It refreshes the changes from attributes of the layers. Actually, i am plotting the points on the map with XY coordinates fields from table in database. what i am trying to do is whenever the data is updated on database it refreshes the data on plotted points too in layer.
Any help is appreciable here.
