"Make this the only selectable layer" does not turn off selectable raster tiles
173
2 weeks ago
Status: Open
SarahMorrison
In ArcGIS Pro, right clicking on a layer and clicking "Make this the only selectable layer" Does not turn off selection for selectable raster tiles. These need to be manually turned off. I think the liklihood of a user needing to select a raster tile, especially when they wanted to turn the selection off on all other items, is low. Raster layers should be included in the "turn off" operation.
2 Comments
ElenaGonzalez_
Good morning @SarahMorrison !
It looks like the behavior you are describing has been logged as a defect. You can review it here:
It looks like the current workaround is to manually toggle the tiled imagery layer off in the Selection view of the contents pane.
SarahMorrison
@ElenaGonzalez_ Thanks for letting me know! I definitely failed to see this, and since my organization is still using 3.6, I still encounter the issue. I look forward to seeing a fix implemented in newer versions. I appreciate the help!
