"Add Data" queue
1541
06-18-2010 07:11 AM
Status: Open
JamiePetersen
Currently, if I want to add a feature class from two different workspaces, I have to add one and then go back into the add data dialog again to add the second.  I'd like to be able to add feature classes to a queue/list and continue browsing for data.  When I am done, all the datasets in the queue are added to the map.
3 Comments
ArcGISUser
Since ArcCatalog is now in ArcMap as a Catalog Window, it is only a matter of time until they remove the Add Data button altogether... my opinion.  Check out 10, you can do everything you are asking for with the Catalog window.
ArcGISUser
Well... Add Data might be kept because of adding basemaps and data from ArcGIS Online.. Other than that, use the Catalog Window.
ChrisRobinson
 This idea could be merged with another idea located here
https://community.esri.com/ideas/1541
