Please Make it harder to Delete A Layout in Pro
3041
08-22-2023 11:27 AM
Status: Closed
TiffanyTuro
I would like to suggest changing the tiny x that will delete your layout- or maybe ask a follow up question.  I have often been trying to quickly look through my layouts and accidentally hit the x, which very quickly deletes said layout!  The only recourse is to exit program without saving.  There is no undo, and if you aren't paying attention, you may not notice what just happened.  I would prefer to right click to delete layout, just please make it a little bit harder to do on accident.
Tags (3)
3 Comments
KoryKramer
Status changed to: Closed
Hi @TiffanyTuro That X just closes the layout view. You can re-open the layout from the Catalog Pane (or Catalog view).
For example, right-click> Open; or just double-click one of the layouts in your project to re-open it.
CarlMorrison
Hi Tiffany,
That  "X" does not delete the layout, just closes it, if you look in the catalog and expand Layouts it should still be there.
TiffanyTuro
Thanks for the info!  I had never used the catalog in this way, so I appreciate the tip.
