Persistent Database Authentication across ArcGIS sessions
1161
06-17-2014 04:19 PM
Status: Open
AdamForknall
When using a Database Connection which requires authentication via username and password, the authentication should be carried across all sessions of ArcGIS software which are using this database connection.
So if I connect to a database in ArcCatalog and complete the authentication, and then open an MXD in ArcMap which uses this connection, I should not have to authenticate again - ArcMap could check with ArcCatalog (and other instances of ArcGIS software) to confirm that the connection has already been authenicated, and then let me get on with my work rather than pester me for a username and password again.
2 Comments
Bud
Does this idea apply to ArcGIS Pro?
@SSWoodward
SSWoodward
With an SDE Connection file containing my saved credentials, I am not prompted to provide my credentials again when accessing the file from another ArcGIS Pro project.
Is that what you are asking?
