Option to default annotation geodatabase on convert in ArcGIS Pro
776
03-24-2020 08:39 AM
Status: Already Offered
MattClarkson1
I would like to suggest that there be an option when converting annotation to set the default geodatabase for output. Currently, you have to select an Output Geodatabase. Would it be possible to allow users to set that either to the current project geodatabase, or to the geodatabase source of the data (assuming it is a valid gdb)?
#Annotation
1 Comment
WendyHarrison
you can specify a default geodatabase on the Options dialog under the Current Settings tab.
