Option to 'add all unlisted values' when using symbology based on multiple fields that have domains
1346
09-13-2023 09:36 AM
Status: Open
Rose_Geater
When symbolising on a single field that has a domain, the symbology list of classes picks up all the possible values from that domain, even if they are not all present in the data.
When symbolising on multiple fields (3 being the maximum), the list of classes is limited only to the combinations it finds in the existing data, rather than all possible classes, as with the single field option.
The GUI allows you to 'Add unlisted values' and manually add in the other possible combinations, however this is very time consuming.
It would be great to have an option to 'Add all unlisted values'. This would involve the software looping through the domains of the specified fields and forming all the different combinations it finds.
This would be really helpful, as when using 2-3 fields to symbolise on, it is common to not have every single combination represented in the data, but for future edits to use those unlisted combinations.
Note this could be more complex when using subtypes and subtype group layers, as it should look only for the domains that are relevant to that specific subtype.
1 Comment
Brian_Laws
I agree that this would be a nice feature to have.
I am currently working on some web maps for field editing for our new Utility Network services and found that some of my feature templates were not showing up (they were blank).  It was only on the subtype group layers in which I was symbolizing on multiple fields.  In testing I found that if I added all the missing combinations in my symbology for that subtype then the feature templates showed up.
For example, on just one subtype I was missing 11 combinations and had to add them one by one manually.  It would have been much easier if I could have added them all at once, just like I used to be able to do in ArcMap symbology.
