Open map or layout window using arcpy
2065
07-11-2023 07:33 PM
Status: Already Offered
ToyotaT18
Using arcpy in a Geoprocessing script, I can import a map or layout into the project. However I can't make it 'open' as a new window. It would be really good if this was possible.
3 Comments
JohannesLindner
Is this what you want?
aprx = arcpy.mp.ArcGISProject("current")
m = aprx.listMaps()[0]
m.openView()
l = aprx.listLayouts()[0]
l.openView()
ToyotaT18
Ah, I didn't realise those have been added! I had last looked when I had v2.8
That works well for a map window, yes.
However the layout option gives an error when run from an arcpy geoprocessing script? It works in the python window ok, just not from a gp script. Using v3.0.0
Thanks for pointing out the map option.
JeffBarrette
As pointed out by @JohannesLindner this is already available. Changing status to already offered.
Jeff - Layout and arcpy.mp teams
