MXD Full File Path
802
11-29-2016 10:37 AM
Status: Open
DavidForbuss1
Would it be possible to add the full file path (or have the option to) to the upper left corner of ArcMap that shows which mxd you're currently working in?  There are times when I have multiple mxd's with the same name, so knowing which particular one I'm currently in would be helpful.
1 Comment
RobertBorchert
What version of ArcGIS are you using?  I am in 10.3.1 and it is showing on mine.  Now I don't know if you loaded it in yourself to the image but it is in the image you posted.
What I also do for each mxd where I am going to use the layout is I put the document path in there from Insert > Dynamic Text  > Document Path (or Document Name)
