Multiple Pages in a Single Layout
33075
25
01-13-2021 10:47 AM
Status: Open
jcarlson
Before I came to work at an ESRI workplace, I was an avid QGIS user. Still am, really, but as ArcGIS Pro has developed, I find myself needing to use Q less and less to hack together an as-yet-unimplemented feature in Pro.
(Major props on the eyedropper!)
There is, alas, still one feature that I desperately want: multiple-page layouts.
In the course of my work, there are a number of times when it is helpful to have spatial and non-spatial components on separate pages, and the sheer amount of information in my layout cannot realistically be squeezed into a single page. Or at least, not that the average person could print out. I'm all for digital maps, but I know we have other folks in our county who want it on paper, and I'd like to conveniently oblige them.
The biggest of these items are our Change Records we generate when changes are made to the cadastre.
Here's one for reference.
Combining multi-page layouts with a Map Series would absolutely make my day.
What are my alternatives?
  1. Make each page a separate layout
  2. Use some sort of mail merge procedure to generate the non-spatial pages
  3. Make my layouts potentially tabloid-sized
  4. Use Python
  5. Use QGIS
Options 1 and 2 create separate files, which then have to be merged together, adding more steps and intermediate file storage to what is currently a batch process.
Option 3 we tried, but the increased loading time and unprintable nature of the page was not desirable for our users.
Option 4 is a maybe, but there's no way the spatial component will look half as nice as Pro, especially when it comes to labelling.
Option 5 is what I'm currently doing, but it comes with a host of its own limitations, and means that I have to work in two programs during my "weekly update" process, which is sub-optimal.
Final note: I've tried making a reeeeeeally tall layout in Pro and hoping that in the "Print to PDF" process it would cut them, but no. It just generates a really tall PDF.
25 Comments
JeffBarrette
@jcarlson please keep me in the loop.  We have future plans to create a Map Book tool (vs map series).  map books could include the contents of a map series PLUS all the other components that go into making a final map book project, like title pages, TOCs, index pages, etc.  Currently arcpy.mp is the only solution for what I'm calling a map book.  Some advanced solutions are possible.  Working with your scenario can help us drive requirements.
Jeff
jcarlson
@JeffBarretteWill do! The Map Book sounds really great, too. If I can generate a satisfactory result, I'll email you the nitty gritty.
AlyciaRajendran_esri
Hi @jcarlson!
I am a member of the Reports team for Pro. We can definitely produce those non-spatial reports right now. It just depends on how automated you want it to be.
The first step is creating a report using the feature layer. You can use the UI to modify the report to look how you want.
1. No automation: When exporting this report, there are a few things to consider. A report honors selection sets and definition queries for the layer, or you can use an expression to query a subset of data to use in the report.
In the example above, before exporting your report, you could select the parcel in the map or table, set a definition query for that parcel on the layer, or set an expression in the report--all of which would result in a one feature report.
2. Some automation: Use the Export Report to PDF geoprocessing tool within a model or in the Pro Python window. The tool also honors selection sets and existing definition queries on the layer. You have the option of setting an expression before exporting as well.
3. All automation: You can create, modify properties, add elements, and export reports using the .NET SDK. Similar to using Python to create multi-page-layouts, the content of these reports would be authored in Pro.
Some helpful links:
Overview documentation: https://pro.arcgis.com/en/pro-app/latest/help/reports/reports-in-arcgis-pro.htm
How to set the expression when you create the report: https://pro.arcgis.com/en/pro-app/latest/help/reports/specify-report-data.htm#GUID-07BB1458-EB03-421...
Export Report to PDF gp tool: https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/export-report-to-pdf.htm
.NET SDK: https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/#topic18660.html
I hope this helps. You can contact me via email [email protected]
jcarlson
@AlyciaRajendran_esriThanks for the extra information! I'd thought about going the query layer route and using a query parameter, but often by the end of a busy week, there might be as many as a few dozen reports to generate.
I believe I will attempt the full-automation route, and use reports for the non-spatial elements.
DougBrowning
My use case here is to have page 1 be summary info, page 2 is a table element and maybe page 3 is the map.  So I have a 3 page PDF per feature.
I am not seeing a way to do it.
JeffBarrette
@DougBrowning I believe it can be done with arcpy.mp.  Is Page 1 an ArcGIS Pro layout or is it a standalone PDF?  Page 2 could be a separate layout in the same project with the tabular info and Page 3 could be a third Layout.
You can use arcpy.mp to export each layout into a PDF and then use Python to add them all into a single page PDF.
This code example appends 3 PDFs into one PDF (with 3 pages): https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/pdfdocument-class.htm
Jeff
Amanda__Huber
Hello ArcGIS Pro Team,
We would like the ability to export two separate layouts (unable to use map series for this) into one PDF file for the purpose of condensed electronic pdfs and double-sided printing. We're aware of third-party software for post processing, but I believe other orgs may also find benefit in this functionality.
Please consider this enhancement.
Thank you,
Amanda Huber
jcarlson
Great idea! So great, in fact, that it's actually been requested before, multiple times, I think. I actually posted something similar to this in the past, but even back in 2019, someone was already asking for this.
https://community.esri.com/t5/arcgis-pro-ideas/print-multiple-layouts-in-arcgis-pro/idi-p/941011
JenMar_
Hello,
I am attempting to create a template that allows me to export a two page map (back and front printed).  I am using dynamic tables with a Map Series Pages data frame, where the front page would be a map and the back would include the tables.
I am not an avid programmer, and my staff are not GISers, so I'm wondering if there has been new developments in this area that would allow for multi-page map prints?
Help would be appreciated.
PhilipMarty
@JeffBarretteI've got a similar use case to the post by @DougBrowning. I've got a layout with a chart, map frame, and two dynamic text elements powered by two different query layers. One query layer populates the map, chart, and text elements, and there's separate query layer pulling the any records in the SQL database within the last day that the map series runs off of. I use arcpy to ms.refresh() and export to pdf. Now I'm wanting to add a second page with two additional map frames and append the two pdfs into one, but I'd like to run the export off of the same map series. I can't figure out how to link the second layout map frames to the first layout to line up all the extents. Any thoughts on this? Is it better to do like you suggested above and stick with 1 oversized pdf that I export with pdf tiling? Is that possible in arcpy? Or is there a way to link a second layout extent to the first and have it recognize the extent changes of stepping through the map series rows?
Thanks, this is amazing functionality
