Allow ArcGIS Pro to connect to Microsoft Fabric data sources such as data warehouse, data lakehouse, and SQL database via the SQL Endpoint, using an ODBC connection or some other method. Using the SQL Server database connection does not work currently, even though other tools are able to connect using ODBC driver for SQL Server. This would be useful for using Microsoft Fabric data sources with Query Layers and other features.
I support this idea.
Hi Brad
Support is partial, depending on what you want to connect to:
https://community.safe.com/ideas/sql-database-in-microsoft-fabric-entra-authentication-37811
We recommend you post to the thread, to which I'm subscribed. We can also help with direct communication with Safe Software.
I support this idea! Currently unable to use our query layer due to this issue.
I have a customer, that is looking for a connection to Fabric SQL Database as a query layer in Pro / Enterprise via ODBC as well.
I support this idea. Allowing the direct connection to data in MS Fabric, Dataverse, or a data warehouse to publish a map service/feature service would be great.
This would be great! We have a use case where we transform data in Fabric and we want to visualize this data in an ArcGIS Enterprise Dashboard.
