Map Series maintain extent for all maps
1694
07-18-2023 08:51 AM
Status: Open
JohnNergeBrooklynPark
Posting an idea in reference to this community post. It would be very useful in some situations to have a fourth option on Map Series to maintain a fixed scale AND extent when exporting the maps.
Our specific use case is wanting to export a series of emergency exit maps where each map shows one location in a building and its associated exit routes. We still want to show the full building floor plan, so we want to be able to set a fixed scale and extent and not have them change for each map in the series.
The post mentioned above appears to include a workaround, but it'd be much nicer as a simple checkbox option when setting up the Map Series.
4 Comments
AnninaHirschiWyss
Needed here too 🙂
AubriOtis
I think this is a case for thematic map series. Does that work in this instance?
I don't think so. It looks like Thematic Map Series has you choose a group layer, whereas what I'm looking to do is create a map series from a single layer and make one map per record in that layer.
Thematic Map Series maintains the scale and extent like I need to do, but it doesn't appear to be an option to run it off of a single layer like a traditional map series? So really I need a combination of both - make the series based off a single layer AND maintain the same scale and extent for each map.
AubriOtis
Status changed to: Open
@JohnNergeBrooklynPark Thank you for the clarification! I understand now and have reopened the idea for voting.
