@KoryKramer Feel free to close this idea. Support is submitting bug reports for these issues.
Edited: I removed the part about hovering over the definition query.
Regarding the definition query window:
For an existing definition query that is enabled, the toggle makes it look like it's disabled.
GIF:
Could the UI be improved so that it's clear that an existing enabled definition query is displayed as being enabled?
Thanks.
ArcGIS Pro 3.0.3; mobile geodatabase.
I think you're missing something.
The query has 4 states:
The grey checkmark in the inactive hover state is meant to tell you "Hey, click here to activate this query!"
You have something different going on there: The query shows as inactive, although it apparently is active. Could be that this is due to your more complex query. Try a simple one.
Here's the data and SQL expression -- in case someone wants to reproduce that UI behavior:
Standalone table named roadinsptable:
ASSET_ID: Text
DATE_: Date
CONDITION: Long
| ASSET_ID | DATE_ | CONDITION |
| 1 | 2016-04-01 | 1 |
| 1 | 2019-03-01 | 2 |
| 1 | 2022-01-01 | 3 |
| 2 | 2016-04-01 | 4 |
| 2 | 2022-01-01 | 5 |
| 3 | 2022-01-01 | 6 |
| 3 | 2022-03-01 | 7 |
| 3 | 2018-03-01 | 8 |
| 3 | 2013-03-01 | 9 |
| 3 | 2010-06-01 | 10 |
| 3 | 2022-03-01 | 11 |
SQL Expression:
roadinsptable.objectid IN (
SELECT objectid
FROM roadinsptable r2
WHERE r2.asset_id = roadinsptable.asset_id
ORDER BY date_ DESC, condition DESC
LIMIT 1
)ArcGIS Pro 3.0.3; mobile geodatabase.
Esri Canada Case number #03255222 “Definition query with subquery shown as inactive (incorrect)”
Bug number: BUG-000155660
Synopsis: Definition queries do not appear as active after enabling the query and reopening the definition query again.
Related: Modifying existing SQL expression disables definition query
From the video it's clear there is a bug with that type of complex SQL query. The bug being that when you open the DQ in Properties, it automatically disables itself.
I can't replicate it though. I had a similar SQL query (nested, but no joins) on a mobile geodatabase and it didn't bug out like this. I'm using Pro 3.0.3, btw.
