Make compress file geodatabase compatible with new field formats
529
07-11-2024 05:41 AM
Status: In Product Plan
DuncanHornby
MVP Notable Contributor
I often compress file geodatabases to reduce data volume for static datasets. I am also being supplied , in ever increasing regularity datasets supplied as geopackages. When I import such data into a file geodatabase it takes on the field formats but the compression tool errors with this message:
ERROR 161003: Cannot compress ea_detailed_watersheds. Compression not supported on 64-bit object ID, big integer, date only, time only or timestamp offset fields.
So my idea is to update the compression tool to work with 64-bit object ID, big integer, date only, time only or timestamp offset fields as these will become increasingly more common.
3 Comments
BSBlagojevic
Yes!
AlfredBaldenweck
I'm surprised that that wasn't taken care of when the new field types were introduced.
SSWoodward
