M Values Auto Update and Relationships
1727
02-13-2025 09:46 AM
Status: Open
Miralem_Zeljo
We would like to see an enhancement that automatically updates M value without the need of right click set distance - X and Y values auto update. It would be nice to see M value update when you add vertices or extend route lines. Also, it would be really nice to update next segment to start the M value by using last segment end point M value and auto update if I modify previous segment. We are working on developing tool right now but I feel that this should be a functionality out of the box to allow referencing segments and chose option if I want to have M value entered manually or use previous segment end point as a start of the next line segment.
3 Comments
AyanPalit
@Miralem_Zeljo Thanks for the idea post.
I assume you are using the core linear referencing capability in ArcGIS Pro. It will help to understand what industry segment, data type are you referencing. We see LRS in transportation, utilities, pipelines etc.
Hope you reviewed the options as documented at: Update route measures
Some of your use cases refer to advanced LRS functionality, viz. location referencing that is available with Pipeline Referencing  and/or Roads and Highways
How to choose between linear referencing and location referencing
Recommend looking at the resources provided before custom development efforts.
Miralem_Zeljo
Is there a way to achieve this without spending $4K on the Roads and Highways Extension? We only need the core functionality, not the full suite of features.
Bud
Related:
Arcade Code Review: Set polyline M-values to cumulative length of line
https://community.esri.com/t5/arcgis-pro-questions/is-arcgis-pro-the-right-tool-for-tabular-join/m-p...
