Load Data into a Feature Class should only show matching Geometry in Input Datasets dropdown
201
3 weeks ago
Status: Needs Clarification
RobertBorchert
Honored Contributor
When loading data into a feature class in a Pro Project, only show matching geometry.
When loading data into a feature class you can select the data to load from the input datasets drop down.
This should filter to only show feature classes with a matching geometry.
And it should not show the Feature class as an option to add to the feature class
Point, line, or Polygon, etc
Tags (1)
1 Comment
SSWoodward
Thanks for this Idea @RobertBorchert
Could you help us understand more about exactly how you are loading data.  What tools or workflows are you using.  This will help us understand where this idea should be placed.  Are you using a GP tool? A Wizard? The data loading tool set? Something else?
