LAS related processing: Overwriting input data
1086
05-24-2023 06:43 PM
Status: Closed
真大橋
LAS related functions on 3D Analyst, Point Cloud are overwriting input data as output.
When checking each results on workflow, user need to manipulate like making folders and copy each results.
If output are created and input are preserved, just like other geoprocessing tools, these problems are solved and users are free from frustration.
Tags (1)
2 Comments
KhalidDuri1
Hello and thank you for the message. The classification tools were designed to update the input data because LAS file collections are typically very large and classification is performed in a cumulative process. Were your concerns relating to the tools for classification or some other tools? Would you mind sharing the reason for preferring new output files?
Regards,
Khalid
ValeriaChavez
Status changed to: Closed
Hi @真大橋! This thread has been set to "Needs Clarification" for a while now. As no additional information was provided, I will be closing it. Thank you for your continued engagement on Esri Community.
