Map Series view tab in Map View
3447
6
11-05-2020 11:02 AM
Status: Open
JacqueHamilton
ArcMap has the capability to view different queries of a single dataset within a single map view using Data Driven Pages.  ArcPro has similar capabilities using Map Series, but only in the layout view. I would like the capability to 'tab or scroll through' the different spatial queries within the Map View.  Currently I have to go to the layout view to select the particular query then go back to the Map view.  I don't need the layout view at all.
6 Comments
MarcelSt-Germain
Yes this feature will be useful to make annotations cleanup.
wayfaringrob
Came across this today. Particularly annoying when using the clip to index feature option is being used.
MitchellDrennan
Yes! The ability to use Map Series in the Map View would be great. I had lots of workflows in place using Data Driven Pages in ArcMap, and now those workflows are having to be re-imagined.
Kylesp
ESRI needs to allow the Map Series Navigation Buttons on the Map View.  Currently it is only available on the Layout view.  The workaround is to use the attributes pane, but this doesn't use the Map series definition criteria such as scale and rotation.  It's very difficult to perform lots of editing to layers thru layout.
Kylesp
Please Install the Map Series Navigation Buttons on the Mapping Pane like it was in ArcMap.  Currently it is only available on the Layout view.  The workaround is to use the attributes pane, but this doesn't use the Map series definition criteria such as scale and rotation.  It's very difficult to perform lots of editing (in a map series)  thru the layout.  To do so, you have to click activate/deactivate each time you need to navigate to the next location of the Map Series.
MitchellDrennan
Introduce Map Series functionality to Maps instead of only Layouts, similar to the way one could use Data Driven Pages in ArcMap. Another button could be added to the "List by:" options at the top of the Contents pane to list by Map Series, similar to the way it is in a Layout.
With the ability to do this in a Map, one could "step" through each extent of a Map Series and retain the ability to zoom in/out, pan, and select/modify features, etc., without having to activate and de-activate the Map Frame each time.
See this ArcGIS Pro Question for a discussion of this idea
