I'm trying to automate the set up of layouts using templates, dynamic text, etc. One problem I'm running into is that some elements aren't always the same size, which means they can start overlapping each other and have to be manually repositioned. If elements could be in a group that automatically pushes each other around to accommodate, that would be fantastic.
An "intelligent group" or "flow" would be similar to a normal group except it would have settings such as: anchor point, flow direction, alignment, spacing between elements, maximum dimensions, whether elements shrink or create more columns, set order or allow rearrangement for best fit, etc. All of these settings are similar to some element types already.
Since the flow is not itself a text element like a frame in InDesign, there must also be a new type of text element that allows its container to grow only in certain ways, e.g., the width is set but it can expand up or down as far as necessary.
It could end up somewhat complex, but it still seems like a worthwhile idea for enhancing automated workflows, particularly map series.
I often include a table of coordinates in my layout just below the legend.
Since this is usually in a map series, and the legend displays dynamically just the content of the current page, there is a differing amounts of space between the legend and the table. This is especially annoying when the table is quite large and could use the extra space very well.
It would be neat to be able to "integrate" (for lack of a better word) the table in the legend, so that it moves up and down dynamically with the legend content.
Love that idea, just had to go to a Table Frame for some data instead of using a second legend in one of my maps, and this would have worked great. The alternative for yours for now I would think would be put the table at the top so the legend expanding up and down is underneath it. Unless the table expands too...
