Edited:
For Model Builder purposes:
It would be helpful if there were an OOTB geoprocessing tool for creating a new feature from scratch in an existing feature class. Or create a new row from scratch in an existing standalone table.
Similar to @JohannesLindner's Python solution, but as a built-in GP tool: Is there a GP tool for inserting a row into a standalone table?
We’d manually specify each of the field values, including X&Y if it’s a point FC.
Standalone table example:
This is a great idea. It would also be nice if there was a way to add rows in an ArcGIS Online table without using desktop software.
@Bud the Append tool accomplishes this.
Doc: https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/append.htm
@JonathanNeal Does the append tool let you create a feature or row from scratch? As in, manually enter the field values, rather than import from an existing record from a FC or table?
I updated the question.
@Bud Perfect I see. This will complement the Iterate Features Tool nicely and allow for a data confluence to append a new record.
+ @ShitijMehta For review.
Regarding:
Should you submit a separate idea for that to ensure it's seen?
Hi Bud,
Thanks for this idea! I have a few questions:
From the proposal - tell me if I got this right - the proposed tool basically inserts one row at a time and adds value to different fields in that inserted row.
Thanks!
From the proposal - tell me if I got this right - the proposed tool basically inserts one row at a time and adds value to different fields in that inserted row. Yes.
Thanks!
