Import KML attributes in ExtendedData nodes
7112
10
03-20-2014 08:07 AM
Status: Implemented
jessemaps
The Kml To Layer tool does not import data attributes contained in a KML file. Handling attributes should be an important function of a file import utility in the leading GIS software.
The KML spec for including attributes in KML GIS data is here: https://developers.google.com/kml/documentation/extendeddata
10 Comments
BruceHarold
Hello Jesse
Data Interoperability extension supports reading typed data from schema and schemadata elements in KML/KMZ files.
More frequently we see untyped data in description objects i.e. HTML, this can be extracted using the approach in this discussion.
JeffBishop
When we import a KML/KMZ using the "KML to Feature" tool, we lose all of the attribution of the features. Only the name of the feature is preserved. I hear Global Mapper can do this and I also hear the Interoperability Extension allows this, but we have no licensing for either and I was hoping such a basic feature would be made available by ESRI.
jcarlson
It's a nice idea, but part of the problem is that KML/KMZ is a non-tabular format. Some programs may behave otherwise, but an individual feature in a KML/KMZ can have any number of attributes unique to itself within the ExtendedData element.
        <ExtendedData>
          <Data name="Latitude">
            <value>42.6452348</value>
          </Data>
          <Data name="Longitude">
            <value>-87.8540913</value>
          </Data>
          <Data name="Month">
            <value>July</value>
          </Data>
          <Data name="Present">
            <value/>
          </Data>
        </ExtendedData>
I imagine it was a development decision to just keep it simple, rather than potentially have a massive table with mostly null values.
Still, maybe something like "attributes to keep" as an option in the tool would be nice, so the tool could look in the ExtendedData element for "<Data name="your-attribute"> and pull out the value. It would be a good enhancement.
MargaretCrawford
The development team is researching the use of KML ExtendedData attributes for the KML To Layer conversion tool.
DanielMurillo
Hello@MargaretCrawford Is there any BUG or EHN number we can keep on checking to see the advance of this?
MargaretCrawford
Hi @DanielMurillo, you can track the issue with BUG-000126776
KoryKramer
@DanielMurillo it may be easier to just follow this idea. We strive to keep statuses updated and accurate. But here is the link to the bug that Margaret cited: https://support.esri.com/en-us/bug/the-kml-to-layer-tool-does-not-honor-the-attributes-for-bug-00012...
(Note that we typically don't keep ideas open that are legitimately bugs. I think there is some nuance that understandably makes this a perceived bug and in order to address that, we would need to address this idea.)
DanielMurillo
Hello @MargaretCrawford and @KoryKramer  for the info provided.
We will tell the customer to kudo this idea and hopefully this will be catched in any version soon.
DrewFlater
Support for ExtendedData attributes in KML is being added to the ArcGIS Runtime KML parser that is in use across Esri products. KML To Layer is being actively worked on for the last several months to support this parser. We are hoping this will be complete in the near term, perhaps the ArcGIS Pro 3.5 release.
MargaretCrawford
This idea has been implemented in Pro 3.6 with the new KML to Geodatabase tool
While the tool is called KML To Geodatabase, you can output to shapefile, memory, and any geodatabase format. And the tool supports converting KML attributes in an Extended Data node to individual attribute fields.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/conversion/kml-to-geodatabase.htm
