Import and export field map configuration
1386
10-24-2024 02:19 PM
Status: Already Offered
Bud
Legendary Contributor
ArcGIS Pro 2.9.5; Oracle 18c 10.7.1 EGDB:
I'm trying to import a .CSV into an enterprise geodatabase as a standalone table:
Catalog > right-click a .SDE connection > Import > Table > Table to Table GP tool
I've gone to great lengths to set the Type parameter for each field to the appropriate type. However, I've gotten an error when running the Table to Table tool.
As far as I can tell, I've just wasted an hour of my time because I will lose the field types that I set up. Ideally, I'd be able to export the Field Map configuration as a file (readable with a text editor) and then import it during a different attempt at using the Table to Table tool.
2 Comments
Bud
KoryKramer
@Bud It looks like you're submitting your idea against 2.9.
See https://community.esri.com/t5/arcgis-pro-ideas/save-field-map-field-matching-schema-matching/idc-p/1... where the ability to export (and then load) a field map definition was added in ArcGIS Pro 3.2.
