If a field is deleted/added to a layer have that change reflected in metadata
502
01-10-2025 10:23 AM
Status: Open
Laura
by MVP Regular Contributor
I’m currently performing an extensive database cleanup, which involves adding and deleting various fields, as well as adding metadata to each layer. During this process, I noticed that fields that were deleted still appeared under the "Fields" tab in the metadata. I reached out to support, hoping there was a way to sync the attribute table fields with the metadata fields. However, they explained that this is expected behavior and suggested submitting an idea to the community.
My goal is to find a way to automatically sync these fields, so I don’t have to manually add and delete fields in both the layer and the metadata each time a change is made.
Tags (1)
