I3S editing
4424
6
08-13-2019 07:35 PM
Status: Implemented
KarlTian
How to edit and update an exisiting slpk file? Like move or rotate, geometry edit, and more.
I know that we can edit a published scene service, but with so many restrict.
Why not add the edit funtion to ArcGIS Pro and Runtime, do all editing locally? on a local slpk file?
6 Comments
Andrew--Johnson
Hi Karl,
Thanks for your feedback. We do not currently have plans to support editing of scene layers packages (.slpks). For editing the features themselves we recommend publishing a scene service with an associated feature service to a portal (ArcGIS Online or Portal for ArcGIS).
For scene layer packages, we are looking to provide support for clipping, rotating, and reprojecting to another coordinate system.
Can you clarify what you mean regarding restrictions you are encountering editing scene services? Also, please provide some more details in specific workflows where you would like edit the features in an slpk over a scene service.
thanks!
Andrew
KarlTian
Hi Andrew,
When editting a scene service, you have to be prepared when publishing. and only apply to 3d object and point.
It's really not convenient, particularly when dealing with existing old data.
For now in my own work flow, I mostly need append/merge and texture editting.
Thank you.
Andrew--Johnson
Hi Karl,
You mentioned texture editing. Are you looking to do this on a integrated mesh or building scene layer?
thanks,
Andrew
KarlTian
Actually mainly on 3D object and building, since you currently not support Revit's texture.
Thank you.
Andrew--Johnson
Hi Karl,
Some of this has been implemented and some is in the pipeline. Here's what we have for slpks so far:
ArcGIS Pro 2.6: Integrated mesh modifications
ArcGIS Pro 2.7: Support for projecting slpks in the Project Tool
ArcGIS Pro 2.8/2.9: Support for clipping\merging slpks
Andrew--Johnson
Closing as previous items mentioned have been implemented in previous versions of ArcGIS Pro.
