hasCurve Arcade geometry property
2048
02-25-2022 02:35 PM
Status: Under Consideration
Bud
Legendary Contributor
It would be helpful if ESRI could add a hasCurve geometry property to Arcade.
Use case:
When using Calculation Attribute Rules to update the shape column of features, it would be helpful if we could check if polylines or polygons have true curves or not.
https://developers.arcgis.com/arcade/guide/types/#polyline
Thanks.
Tags (1)
2 Comments
CraigWilliams
Since curves come into the active language pre-densified AND that conversion is sometimes done server side, it is difficult to provide this capability. This is a valid request for when curve support comes to the language with the caveat that some draw cases leveraging server-side caches may be pre-densified.
Bud
@CraigWilliams
Thanks! In the meantime, I wonder if this might be a valid workaround:
Compare $feature.shape_length, which is the true length, including true curves...
vs.
Length($feature), which is the pre-densified length, where true curves have been converted to straight segments.
If there is a difference between those two values, then that tells us that the line has curves.
What do you think? Do you see any issues with that approach?
