Freeze Field in the Attribute Table should work the same even after a table join
2008
08-07-2023 11:16 AM
Status: Closed
AndrewWallick
The "Freeze Field" feature does not work the same way when a table join is on the feature class. Normally if I want to freeze a field like the highlighted "NAME" field below, I right-click NAME, select Freeze Field, and it moves over to the left of the attribute table, adding the darker grey bar to show it's frozen.
But I've noticed that if I have another table joined to the first table, then when I try to Freeze Field, it just freezes the first field in the table. In the screenshot below, you can see OBJECTID is frozen, even though I clicked on NAME to freeze.
5 Comments
AlyciaRajendran_esri
Hi @AndrewWallick!
Thanks for reporting this. What version of Pro are you using?
Thanks!
- Alycia
AndrewWallick
@AlyciaRajendran_esrithis is on 3.0.5, thanks!
@AndrewWallick that helps. We fixed this bug in Pro 3.1. Are you able to upgrade?
AndrewWallick
@AlyciaRajendran_esriNot yet, we're waiting until we upgrade our Enterprise. But great to know that the bug is fixed for once we do upgrade!
Status changed to: Closed
This was a bug fixed in Pro 3.1.
