Floating point reclassify for raster
2641
01-29-2012 01:36 PM
Status: Open
Atma_BharathiMani
The multiple reclassify tools in the spatial analyst toolbox (Reclass, Lookup, Reclass by ASCII file, Reclass by table) do not support a floating point output raster. It would be great if this can be implemented.
The present workaround I follow is to multiply the required floating point numbers by a large number, run the reclass tools to create an integer output and then use the divide tool to get the required floating point raster.
2 Comments
DuncanHornby
Want to bump this  up as recently I have found the need to reclassify range of pixel values into floats and was surprised to discover the reclassify tool only supports integer format as output.
I have a work around but it would be good if the reclassify and reclassify by table accept floats as an output format.
LarsUngerechts
Yes, there are workarounds, but a straight conversion to a floating point raster would be really welcome!
