Fix this Pro Bug: Import XML is missing schema preview
2377
09-15-2018 11:29 AM
Status: Implemented
ThomasColson
In Arc Map, when importing a XML workspace document, if the XML contains a feature class of the same name, not only does it append the name, it give you the opportunity to rename it, in addition to showing you a sort of preview of the schema. In Pro, no such thing, just this useless message:
WARNING 001163  C:\Users\username\Documents\ArcGIS\Projects\MyProject30\PRO_TEST.sde contains existing datasets. These datasets will get created with new names.
2 Comments
ThomasColson
Disappointed to not see this addressed in 2.3. Why was it removed in the first place?
KoryKramer
This is implemented in ArcGIS Pro 3.3. See Your Ideas in ArcGIS Pro 3.3 for a full list of all user ideas you can look forward to! And be sure to check out the release blog and what’s new help topic and video to learn more about all the new features and functionality in the release.
