Field calculation in Edit Vertices pane to batch calculate M and Z values
995
10-22-2024 12:11 PM
Status: Open
Bud
Legendary Contributor
In the Edit Vertices pane:
A field calculation-like mechanism to batch calculate Z and M values. For example, select a subset of a feature's vertices and set the M value to the cumulative length of the line, null, 0, or something else.
There might be use cases for adjusting X and Y coordinates too, such as batch-moving specific X coordinates to the left or right.
2 Comments
Michele_Hosking
I don't know about Z but you used to be able to do this for M values in ArcMap.  From memory it was a bit round-about but possible.  And them they took that option away somehow in later versions of ArcMap.  Definitely would be great to have it back.
Scott_Harris
Just an FYI
For basic batch updates to Z and M on selected vertices, you can use the Update Z Values and Update M Values commands:
https://pro.arcgis.com/en/pro-app/latest/help/editing/edit-vertex-z-values.htm
https://pro.arcgis.com/en/pro-app/latest/help/editing/edit-vertex-m-values.htm
Example:
For more complex updates to M values on a subset of a route, you can use Define Line Portion along with the M Value context menu commands: https://pro.arcgis.com/en/pro-app/latest/help/editing/define-a-portion-of-a-route.htm
