Enhance Append Tool to Allow Python/Arcade Expressions for Unmapped Fields
8039
19
07-26-2022 06:33 AM
Status: Under Consideration
feralcatcolonist_old
Enhance the Append Tool's functionality by allowing users to utilize Python or Arcade expressions to fill in output fields that do not have a 1:1 match between the two data sets.
Example:
Many exploratory data analysis feature classes start from source data with their own attribution. In the process of analysis, an individual may add/remove some fields but otherwise keep the data similar. One workflow is to then append additional records from the source data, selecting "use the field map to reconcile field differences" is useful to just add the new data, but then the user has to go into the table, highlight the newly added records and then run field calculations for each of the new columns their analysis dataset might have.
Or a different example, you have two datasets that are similar, but one is missing some relevant individualized fields-- --or has the same data in incompatible fields (it has a string and you need a numeric). You can create these fields easily enough with a field calculation expression and should be able to do this at the point of entry within the append tool.
The enhancement would look this, for a field(s) you could write in expressions to fill out the data programmatically as it uploads to your established dataset.
19 Comments
KoryKramer
JonathanNeal
Status changed to: Closed
@Bud Yeah because the number is too large. Doubles and DateTimes are 64-bit and can hold a large value than the Long data type.
For trivia night, there is also %t%, %n%, and %v% (%i% is legacy replaced by %n%).
We are seeing this as a duplicate of https://community.esri.com/t5/arcgis-pro-ideas/enhance-append-tool-to-allow-python-arcade/idi-p/1195... will link it in our internal tracking.
Our thought on how you can accomplish this now is to use the Enable Editor Tracking tool. The field will automatically generate a Creation Date Field.
Secondly, maybe you can use the Calculate Fields 3.1+ tool. We enabled a where clause that can fill in the timestamp on empty field values in a pre/post processing step?
Example input:
datetime.strptime('%t%', '%yyyy%MM%dd%HH%mm%ss')
Doc link: https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/enable-editor-tracking.htm
JonathanNeal
MargaretCrawford
I have marked this idea as Under Consideration because adding arcade expressions is part of our long-term plan of changes we would like to make to the field map.
RTPL_AU
Add the ability to enter static text as a source for a field when running the Append tool.
When using the Field Map to match source & destination fields it would be handy to be able to set a static text string as a field input.
Scenario:
I want to add the data source or the site name to a field when appending a bunch of new data sources to an existing feature class. Currently I have to bulk add a field to to all the source files and then add the source name (e.g. folder or project date) to them before appending them or I can create a new model and etc. etc.
cmathers
The Attribute Transfer tool exposes the global field mapping setting of the editor and allows for using Arcade expressions rather than simple mapping. It would be great if this was available in geoprocessing tools such as Append to allow the user some freedom to include a field calculation during tool execution. It would slow the tool considerably if users went overboard with it of course. You can do this already obviously with cursors in python but for the non-programmer it would be helpful.
ChelseaRozek
Really looking forward to seeing this implemented
HollyTorpey_LSA
This functionality would be extremely helpful. I often wish I could just calculate an unmapped value during the append process instead of having to do it in a separate step.
MattRingel
Yes! I wish I could upvote this idea a thousand times.  This would be so much better than the current workaround.
