Dynamic Spatial Definition Queries
3537
14
10-01-2025 05:45 AM
Status: Under Consideration
DavidFotheringham1
The inclusion of spatial based definition queries to 3.5 is great. My immediate thought was to check if they were dynamic, i.e. if my polygon extent changes does my definition query update accordingly. The answer is no. It sticks with the original geometry unless you go back in and reapply the query.
I think there should be an option to allow this to be dynamic (it would be for attributes). I might be using a polygon I don't control / have ownership of and don't know if it has changed. My queried data would be out of data in that case.  (see my picture example below. Blue points are in the definition query. I updated the polygon extent but the blue points are not changed).
Red points not captured when polygon extended. Blue points are part of definition queryRed points not captured when polygon extended. Blue points are part of definition query
14 Comments
JoshuaBixby
@TanuHoque , thanks for chiming in on this discussion and for considering the idea.  @DavidFotheringham1 , thanks for posting the idea and getting the discussion wrong.  I am always open to being wrong, even happy at times about it, when it means improvements come quicker than I expected.
TanuHoque
thank you all for your quick responses.
Cory__Williams
Adding dynamic capabilities to this function would be extremely useful, in conjunction with Map Series! We often have to map features using Map Series, but the data is not linked by attribute. Which results in us having to create additional datasets to cater for this, or manually re-doing the spatial query.
Having the ability to have a map series, which will only capture features within the polygon that we are wanting to show would be extremely useful!
TravisColeHC
At our County government, data is constantly evolving—areas are annexed, section corners are surveyed and updated, tax districts are revised, and many other layers change regularly. Making these spatial queries dynamic would be extremely valuable, allowing us to apply them to specific layer types and meet the needs of various corporations or county departments that simply want their data displayed without the rest showing.
Currently, I have a specific need involving planning districts. I need to query a single planning district for one of the corporations in the County, but I also want that query to remain dynamic so that if the boundary changes, the data automatically reflects the update.
