Drag Catalog item to wizard parameter
413
10-18-2024 04:12 AM
Status: Open
Bud
Legendary Contributor
ArcGIS Pro 3.3.2
I'm able to drag an item from the Catalog Pane > Project tab to geoprocessing parameters. Such as drag a file geodatabase from Catalog down to the desired tab name (Geoprocessing tab), and then up to an output parameter in the GP tool. Use Catalog Pane to enter GP Input parameter
However, I can't do the equivalent when working with a wizard. I can't drag a file geodatabase to the Export Raster wizard's Output Raster Dataset parameter.
That's unintuitive. The Geoprocessing pane and the Export Raster pane look similar in Pro. Users would expect them to have the same functionality. Could dragging functionality be added to wizard panes in Pro?
I'm aware that I can copy/paste the FGDB path. But I think dragging would be worthwhile since it is more efficient/intuitive, and would be more consistent with GP tools.
