ArcGIS Pro can sometimes take severl minutes to Initialize open editing tools such as Move or Edit Vertices when changes are made to the selection. The 'Initializing Tool' step can sometimes take several minutes after small changes are made to the selection when working with feature services. I recommend that ESRI take a look at this performance issue in future versions of ArcGIS Pro and possibly consider not initializing the tool until a specific command such as 'Remove Vertex' or 'Add Vertex' is selected. This will remove redundant initializations each time a selection changes with the tool ribbon open. The performance increases dramatically when the tool ribbon is closed, but it would allow users to be much more efficient if selection could be changed efficiently while continuing to use the same tool.
ArcGIS Pro can sometimes take several minutes to Initialize open editing tools such as Move or Edit Vertices when changes are made to the selection. The 'Initializing Tool' step can sometimes take several minutes after small changes are made to the selection when working with feature services. I recommend that ESRI take a look at this performance issue in future versions of ArcGIS Pro and possibly consider not initializing the tool until a specific command such as 'Remove Vertex' or 'Add Vertex' is selected. This will remove redundant initializations each time a selection changes with the tool ribbon open. The performance increases dramatically when the tool ribbon is closed, but it would allow users to be much more efficient if selection could be changed efficiently while continuing to use the same tool.
Thanks for the feedback, @Dwarburg.
What version of ArcGIS Pro are you using?
What kind of data are you working with, ex. Utility Network, Parcel Fabric?
I have a similar issue while working with very large polygons on a local version of the Parcel Fabric. If I'm editing vertices or moving a polygon, it will take several minutes to initialize and several minutes to calculate when I'm done editing.
@DenverBilling Have you reached out to Esri Technical Support? They can help investigate performance issues and log a bug, if needed.
yeah that is very annoying. my workaround or my "habit" is I always close the modify features so it does not automatically "initialize" the editing of the vertices.
I got a new laptop a ZBook G11 Workstation, that has the same ArcGIS Pro 3.2.2 (like my other 2 machines), but unable to edit vertices of a linear feature longer than 2km. Whilst I can instantly do it on my two other machines. It is same UN feature data and exactly the same GlobalID but different behaviour. I always end up killing the task because it gets stuck on the "Initializing Tool" message.
